All 650Fs I cannot equip the quickshifter for my model
Stevenlee
Mar 11, 2021
hello i have a problem about my bike
cbr650f
My motorcycle cannot operate when equipped with a rapid movement
Can you help me
Stevenlee
Mar 11, 2021
Could you translate that into English please. Thanks.
Sorry
cbr650f
Can you help me
Stevenlee
Mar 11, 2021
So it’s fair to say that something was not properly done during the install. Recheck your wiring and connectors.
because I see yellow / red 12v wire of 2 ignition coils and 1 wire connected to the map sensor.
Therefore, when the ignition is off in milliseconds, there will be map sensor disconnect, the motor will be disconnected from the engine and error
Stevenlee
Mar 11, 2021
why would a QS go near the MAP sensor? I thought it killed the injectors to unload the gearbox?
because I see it with the same yellow / red line
So is there a way to stop the ignition but not to the injector system
I see 12v wire of igniter coil linked to map sensor and fuel pump relay
please post the installation instructions so we can help you decipher what wiring connections are proper and what ones are detrimental.
Stevenlee
Mar 11, 2021
This is the problem i am having
You have to be missing something somewhere or tracing the wrong wires because a quick scan of the wiring diagram for the bike and the instructions you posted do not show any wires going to, or using, the MAP sensor, only the coils, fuel pump system and ECU.
Not trying to be a jerk here but I suggest two things:
1. Taking it somewhere to have it installed, or at least having someone with a better electrical knowledge help you.
2. Get a different QS because this one literally takes your coils power leads and runs them through the their box all the time. It it ever fails or glitches, you have a dead bike. The better ones use the side stand switch or other non-invasive means to cut ignition.
Otherwise the install is pretty straight forward from what I can see And does not go near the MAP sensor.
Stevenlee
Mar 11, 2021
Bạn phải thiếu thứ gì đó ở đâu đó hoặc dò nhầm dây vì quét nhanh sơ đồ nối dây cho xe đạp và hướng dẫn bạn đăng không cho thấy bất kỳ dây nào đi đến hoặc sử dụng, cảm biến MAP, chỉ có cuộn dây, hệ thống bơm nhiên liệu. và ECU.
Không phải cố gắng trở thành một kẻ ngốc ở đây nhưng tôi đề nghị hai điều:
1. Mang nó đi đâu đó để lắp đặt, hoặc ít nhất cũng có người có kiến thức về điện tốt hơn giúp bạn.
2. Nhận một QS khác vì cái này thực sự lấy dây dẫn nguồn cuộn dây của bạn và chạy chúng qua hộp của chúng mọi lúc. Nó không bao giờ bị lỗi hoặc trục trặc, bạn có một chiếc xe đạp chết. Những cái tốt hơn sử dụng công tắc chân đế bên hoặc các phương tiện không xâm nhập khác để cắt đánh lửa.
Nếu không, quá trình cài đặt diễn ra khá thẳng so với những gì tôi có thể thấy Và không đến gần cảm biến MAP.
I had it attached but it seems to be useless, as the motorcycle still shows engine error after I shift gears in gear 3
I can make friends with you through facebook
