Here's the frame with the V4 engine. It's still early in the build, but the rough shape is coming out already.
The front assembly. Forks, wheel, triple clamp, brake fluid reservoir. No dash yet, it's coming.
Third pic is a progression of the first pic. Now it shows the gearbox assembly. It works too! It's a 2-speed gearbox which can be set to neutral, first or second gear with a lever. When you set it to neutral, the pistons won't move up and down in the cylinders as you rotate the rear wheel, in first gear they do and in second gear the torque feels a bit different.
Swingarm still detached from the frame.
Last pic shows how far I got. The other side already has the fairing paneling on.
So far I've spent two short evenings on it. I guess 4 - 5 hours so far.
