CB650F HELP NEEDED!!
royroger
Aug 25, 2023
G'day boys, I've found myself in a situation where I need to get my bike through a road worthy, problem is the bike (cb650f/ABS) crackles and pops and makes all sorts of great noises, Honda says 2k for an oem exhasut. Any suggestions on a cheaper way to achieve 95db and no backfiring?
Brian C.
Nov 26, 2021
Northwich
I assume you have a modified exhaust? Look at the Pair valve removal thread, this should reduce the Backfiring and Popping. Don't know if it will eliminate these, however it should reduce the problem.
Also some interesting bits here.
A used OEM pipe should be extremely cheap to buy, absolutely no reason to buy new.
