All 650Rs Flush Mount Turn Signals For 2021 CBR650R
Scogs13
May 8, 2021
Hey does anyone know where I can find some nice flush mount turn signals to replace the stock ones for the 2021 cbr650r?
thanks!
Mar 17, 2018
thanks!
You will need to contact them to figure out which ones fits correctly.
I have a pair on my CBR650F, but I recycled it from my Ninja 250R 2008. Had to use a Dremel on the light to make it fit my Honda.
They are bright and worth it.
motorider
May 6, 2021
I've been looking for flush mount front turn signals and an integrated tail light for my 2019 CBR650R for a while now. I have not tried any yet, but this is what I have come up with for options. Let me know if any of you have tried these products and what your experience was with them. Most of these require some level of modification to the fairing or the mounting hardware.
TST Flush Mount Signals $20
CBR650F Installation (Requires modifications to stock signal mount)
TST LED Halo-1 Flush Mount Turn Signals for Honda $60
TST adjustable LED Flasher Relay $20
TST Signal Plug converters $12
Proton 500 Signals $80
X-Arc Signals (Rear Signals) $110
TST LED Integrated Programmable Tail Light for CB650F/CBR650F $125
No modifications required for the 650F only
I have an integrated tailight, indicator foot pegs and integrated lights on the mirrors comming. I plan to finaly order flushmounts to finish off the look but I am holding out until I have all the items so I can check exactly what wiring I need from TST or other places. I may go with running mate on the flush mounts.
motorider
May 6, 2021
Please let me know how it goes and post some photos. Which tail light did you get?
There was another one floating around but the quality looked crap. The unit is in transit now and Ill fit all the lights on at the same time once I have everything ready. Who knows how long that will take.
Big
Mar 12, 2021
Tell me. Will they work?
Tony650r
Nov 30, 2021
It’s hard to say for sure, because the dimensions they give for the signal are not at all detailed. Dimensions when looking at the bike and mounted signal from the side perspective, the width fits (longest measurement). But the height, looks like it would leave a small gap without spacers. See the measurements I took when I went down this rabbit hole last winter: A3B2EFCB-B7C1-4490-BD13-188D1EAE9A0F.jpeg
I’m leaning towards yes, because their not designed for any specific bike. But not a perfect fit, for sure you will need spacers kit or they won’t stick out enough. Looks like Denali has 1 inch spacers to purchase separately, but I think it will stick out too much. I bought these:
https://www.ebay.ca/itm/13376778615...2pcpzkbr-q&var=&widget_ver=artemis&media=COPY
But you would have to drill a hole for the bolt. The wire would pass through the existing hole. I bought pretty much these signals, but different name, as looks like their copied and rebranded endlessly. https://www.ebay.ca/itm/37369447842...2pcpzkbr-q&var=&widget_ver=artemis&media=COPY
  • Like
Reactions: Big
Tony650r
Nov 30, 2021
46353, member: 6156"]
[/QUOTE]
My final results:
9E8093B0-7EC3-414D-A01B-7E7082DFA945.jpegE35FB72F-70F4-45D0-918F-715D94D1FE0C.jpeg5F6B5A93-2B6C-44B8-88B2-C87C9A1A2B2F.jpegA6B89BB1-83B1-454E-9B6F-D0B37525D3C2.jpeg
  • Like
Reactions: Big
