CB650R Flasher relay
Verdi
Aug 15, 2020
Can you send me a picture location of the flasher.
Cb650r flasher 2 pin or 3 pin?because i want to replace it with flasher led
Thank you very much
koofdome
Apr 27, 2020
Chicago, USA
Where is the cb650r flasher relay
I believe it is the exact same for the R
I was able to get mine out without unhooking the fuel lines to totally remove the tank. Just swiveled it up, and used some bungee cords to hold the tank to the tail. Or use a wood stick to prop it up while you work.
U need small hands to get to that dam relay lmao!
MrFritz86
Sep 28, 2019
Spring Hill, TN
THIS
Exactly the same
shuhan
Aug 14, 2021
Toronto, Canada
Sorry for reviving an old thread. I've got a 2021 cb650r and can't figure out which module is the flasher relay. The plastic cover on mine seems to be different from the videos. Can anyone point me in the right direction?
MotoDonner
Feb 10, 2021
The cover is different on the 2021 version but still same procedure.
Does relay have a limit to the amount of lights it can operate? Say if I was to add 2 more pairs of LED indicators 1 front and 1 rear. I was never able to get a clear answer.
All relays will have a current limit you don’t want to exceed, the OEM unit is very picky with wanting a certain load or it won’t flash where an aftermarket flasher will work correctly up to its rated load.
