• Welcome - be sure to add your motorcycle to the Showcase!
CB650R Error code help
Debz
Aug 25, 2024
Help plz, I have had the engine management light come on today, I have joined the brown to green wire with a fine wire in the obd plug (hope this makes sense) and the engine management light does 3 long and 6 short flashes, After several hours of searching everything relating to the cb650r (2021) I cannot find anything that relates to this code, can anyone help on this ? I took it to mean code 36 as the long flash represents 10, am I correct ?
Any help appreciated, thanks
Debz
Aug 25, 2024
Thankyou, shall investigate this in the daylight
