- May 16, 2017
That's good news THOMAS. Sometimes these little niggles get in your mind and we think the worst, talking about it can help, and when its sorted move on to the next worry lol. I don't think these old girls suffer too many problems.
Noises I get from the bike.
1200rpm, in moist conditions and I get a misfire of sorts, the PAIR system rattles stupidly.
3000rpm: buzz in instrument cover plastics.
5000rpm: hard clunking through the bars. sort of like a hammering. but I also asked the salesman about the harshness of the bike on a flat throttle on the bike when I test rode it, 105,000km ago. It felt like a cylinder was running lean or in need of a carb balance.
6000rpm+: high rev vibrations typical of an inline 4 with no balance shaft for secondary reciprocation forces. can come through bars, pegs and other but I also look to not crash into stuff when in that part of the rev range so, it's mostly out of mind.
Hard to pin down stuff.
Clutch noise. it makes a bit of extra noise most of the time which is mostly noticeable when you take the slack out of the actuator cable* and such or pull it in all together.
* I do lots of work in traffic so cover the clutch a great deal. thus I get to notice these noises.
The Chain
An older chain can start catching the edge of teeth on the rear sprocket and as such increase incidental noises as it catches. this is most often noticeable during acceleration and is a good sign to review the end of life replacement of the chain.
Re the 3000rpm buzz.... try small flat washers under rear vision mirror mounting bolts. It fixed mine!
Remove the mirrors from the fairing... turn mirrors upside down and place 4 small flat washers on bolts and refit mirrors. Washers go on bolts between mirror base and fairing.I'm curious to try it out. Do you mean between the fairing and the mount, or between the mount and the mirror?
No pair valves, well that's one less job 😎I started running 94 octane gasoline and my knock got far less loud and often so I am definitely thinking the pair valve is my issue which is funny cause in Thailand my 650F doesn't have them and it's super quiet and smooth. Hopefully more km makes it work in a bit more.
Today I managed to capture it a bit while running on idle after start. It´s not really loud but sice I pointed my phone towards the direction of the "source" you can hear it a bit better. That ticking, rattling in the background. I hope you can hear it. Excuse the quality of the video.
At around 17s I moved the phone and you can hear it a bit more. I guess that is that noise getting a bit louder when slightly accelerating from lower speeds and rpm.
Most BAS units I’ve seen have been rubber mounted and have some movement. I’d think a tight fit would/could wreck the fluid cavity that would activate the tilt sensor. My thoughts at least.
Did the nuts have the paint pen marks that means it was checked/torqued when the bike was assembled?
