CB650R Clutch Pin
BT67
22
9
Hi all
Hope someone can help.....
Have just swapped over the clutch lever on my CB650R for the ASV CRC510.
Easy to fit and all appears to work correctly. However, the new lever does not engage with the little pin just below it? Is this a major issue? I'm not really sure of its function - assuming it's a cut-out switch for something?
Your help is much appreciated.
Cheers
Trev
stevelululu
61
30
Toronto
Hi all
Cheers
Trev
Picture or two would help with your cause
BT67
22
9
Thread starter #4
Thanks guys. Yeah had to add the little tab that came with the lever - similar to the brake lever as described in stevelululu's post.
Cheers
Trev 👍
Goblin
32
23
#5
The little switch at the clutch lever is actually the throttle assist switch. As soon as you engage the clutch lever the throttle rpm is going up to assist you pulling away from a stand still
BT67
22
9
Thread starter #6
Aaaah!
Thanks for the reply Goblin. Really neat feature, makes it almost impossible to stall! The new clutch lever has made such a big difference. Been really enjoying the bike. Been missing it just recently though - currently on holiday in Mauritius for a couple of weeks - living the dream.
Atb
Trev
1,864
1,050
#7
It has a few more functions than that as well. It also allows you (or doesn’t allow) to start the bike in gear and if you have a quickshifter it tells it whether to work or not to name a couple.
BT67
22
9
Thread starter #8
Thanks miweber929
Good info. I actually ordered the quickshifter when I bought the bike back in May - still waiting for it unfortunately!
Eaglemoto
148
97
#9
I didn't know about the increased revs on clutch release until reading this thread, funnily enough it was mentioned in a review article I read today in Bike magazine.
