All 650Rs CB650R tuning issues
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
so i have a 2020 cb650R (american market) have a full black widow 200mm exhaust a DNA air filter and blocked off pair valves. while getting the bike tuned at about 10.5rpm we noticed the hp and trq started to cut out like igniton and or fuel was breaking up. it did this as well on the same bike bone stock just to get an idea of hp. stock the bike put down 80hp and 43trq after a few pulls on the dyno and some tuning done trhough the ecu using woolich racing file for the cb650R we were able to get 88hp and 47trq but was still breaking up and making a consistent poppong noise through the exhaust. does anyone have any ideas on what this could be or what would cause it?
bike has 2800 miles on it we ran it with traction control ON and OFF and neither changed it.
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
Here is a dyno of the stock bike pull as well as after being tuned.
Cbat
May 13, 2018
What's up with A/F up to 5k rpm? Lean. Assume the large chatter at the end is rev limiter?
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
That was just him getting it setup on the dyno, nothing to worry about.
At that RPM you may be hitting a programmed rev limit?
That would make sense if the rev limits weren’t erased in the woolich programming but the tuning lets you turn off all those things including the o2 sensor.
Did you upgrade anything in the fuel system? You may be simply not getting enough fuel to compensate for the increased airflow and decreased backpressure.
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
No I did intake, exhaust, and pair valve then cut holes in the plates behind the intake meshes to get more air but at the same time no one in this whole site has needed to do a fuel upgrade for those mods.
Without being there, its tough to diagnose this remotely. Somewhere early on in this forum, miweber929 @miweber929 made a point about differences between a 650F and a 600RR. One specific point that the Master Jedi reinforced is the 600RR has 2 injectors per cylinder, to accommodate the extra fueling required at higher RPMs. I'm just guessing, but I suspect the stock injectors and the fuel pressure are barely adequate to fuel the motor at 10.5K. Once you free up some ponies, you may be seeing that limitation.
Again, just a remote guess, not a validated test result.
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
after spending some time with it i think we have found the issue, it has to do with the traction control and abs wheel speed sensors not seeing any load on the front wheels and seeing it on the rear, even with the tcs turned off it still does this but when you run it on the street it doesnt do it.
That actually makes sense. MIsmatch of WSS data will trigger the TCS to intervene. I did not mention it originally because a lot of US 650s are not ABS/TCS equipped (I think its standard in Europe). Is ABS/TCS standard on 2019-forward in the US?
ECHELONWARRIOR
Aug 22, 2020
orlando, fl
19 is not standard. you can choose to get it or not
20-21 is standard and can only be had in abs/tcs
honestly i just figured with you turning the system off that it would not have an issue but it seems that no matter what if it sees different speeds it still over rides it. was half tempted to pull the fuse for abs/tcs while on the dyno to get rid of the bouncing but the tuner said it was unneeded so now we are just powering through.
