All 650's Brake Maintenance
robbie_62
Aug 19, 2020
Hi All,
I have a 2015 CBR650F which needs a bit of work,
The Calipers seem a bit sticky and the front discs are down to the limit.
How difficult is it to change the Discs & Pads on the front yourself & also change the Caliper seals, etc
I don't have much maintenance experience yet but I'm hoping to try and do as much as possible myself so I can learn how to maintain it properly
Cheers
Rob
Hi All,
Cheers
Rob
If you can properly support the front end in the air and get the front wheel off, it’s pretty easy. If you can’t do that, or that sounds daunting, I’d use a shop.
I learnt to do all those things in a clapped out SV650s with no garage. I got a deal from a breaker for a spare set of calipers for my bike and so I just rebuilt them and swapped out my worn out calipers as a unit, fixed them and had them on stanby.
This might not work for you, I had o go down this route as I relied on my bike to get to work
robbie_62
Aug 19, 2020
Cheers Jack,
Issue I have is no garage so I need to try and get the wheel off and support the bike while I replace the discs as these are getting very close to the wear limit,
judging from your flag looks like your in Ireland like me, I had to make do with no garage either, not easy! just get a weather app :happy:
To lift the bike just get a front and back paddock stand, they dont take up to much space, there may be more compact mobile solutions around if you google otherwise if space is an issue id just take it to a mechanic.
If you remove the belly pan and fairings, you can support the engine block on wood using a trolly jack (I've seen a Honda dealer do this) which will keep the front wheel off the ground.
Personally I'd use a proper bike stand (Abba is recommended with the front wheel lift option).
robbie_62
Aug 19, 2020
The Abba is the dream bit of kit alright, I have no garage so I am nervous about taking it apart outside as the Irish weather is unreliable at best!
On another note, do you know anywhere to source a replacement radiator, I think prev owner went at mine with a power hose or a wire brush or something, A lot of the fins are missing.
Check ebay for rads, don't go with Chinese aluminium ones. They're cheap for a reason.
Oem rad cost is huge. Import from the USA (partzilla, babbits) might prove more cost effective.
robbie_62
Aug 19, 2020
Cheers Jack, Yeah I couldn't afford to put a brand new rad in at €700, I love the bike but not that much!
That site in Holland lists a different part number for the rad, they have 19010-MEE-D01 which I think is for a CBR600 even though it comes up when I pick the CBR650F
Anyone tried fitting one of these?
I would go secound hand OEM
good spot, drop them an email to double check that, could be a bad listing on their website.
When I was looking for parts for my SV before I rang dealers, some of them ( a local one for me) have a breaking business on the side. I never had any issues with that bike for spares :p
robbie_62
Aug 19, 2020
The SV's seem to be a lot more common and easier to get parts, not too many CBR650's around.
