- May 20, 2018
Just had a look at my pedal and it is sqaure to the the foot peg. I put a straight edge on the pedal sticking out to the side and it is at right angles to the bike. So I think you maybe bent.I do mean the angle at the top.
Thanks for the answer, I appreciate it
You have straightened it then.H there,
Could anybody tell me if the brake pedal on my cb650f is bent or suppose to be like that?
I hadn't noticed it myself but somebody pointed it out and I had dropped my bike on that side a little while ago whilst the bike was stationary.
Thanks in advance
Some bikes have ABS those days !!Lol....I always bend my brake pedal in a touch, using my back brake with my toe only when I need it, nothing worse than catching it with big feet and having the rear end brake up when you don't want it. Done this for years now, an old trick I was shown many years ago. Rarely use back brake at all....keep the power on
And I'm far too old these days for "power on" . Doesn't stop me bending them all the same, both bandit and cb fitted with ABS but you get used to knowing that all you need do is slide boot down casing and you're on the brake. It's an old trick from back in the day.....when only proper track bikes had rearsets and all the rest of us just heated and bent thingsSome bikes have ABS those days !!
