- Aug 27, 2019
I finally found the perfect throttle lock. Check it out. đź‘Ť
Feel the same about cruise control in a car?This must be an American thing. I've been biking for over 40 years and have never met anyone that has or has had one fitted.
The very thought of locking the throttle open scares the living bejesus out of me.
What happens if you doze off? or it malfunctions?
I'll stick with the old fashioned multi variant method
I decided to try it out. Got it installed and tested today. Not quite right on first install. The gap I have is between the smallest and medium pad size. It wouldn't quite hold tight enough with the small one so I'm trying to get it set up better. Hopefully I can get it all done tomorrow. It's late and dark right now.
I've been really curious about that model, nice video. I would probably have bought that over my Kaoko had it been available back then.
The US has very large highways, and that's the only situation I find a throttle lock useful. It's the kind of thing I activate for a minute here and there just to move my right arm a bit during a long ride. Maybe I'd use it more with a user-friendly design. I have a Harley tourer with electronic throttle-by-wire cruise control and it's awesome.
It’s a standard thread. They use thread lock, you’ll really need to grip the end have a solid screwdriver to get them out.I am ready to install my Kaoko on my 2018 CB650F and have a question about the bar end weight threads.
Are they reverse threaded? I've tried to loosen the screw and am afraid to turn any harder in case it is reverse threaded.
Thanks in advance.
Wayne
