GoaCBR
- Feb 1, 2016
I've actually got the auto tune module with me, but the Wide O2 sensor is a 22mm one whereas the original one is 18mm. I would hate to have to drill into the Titanium F*** it up and then have a wasted Akra pipe.If the air density (linked to altitude) is similar the results should be pretty close.
I need to back up the maps anyway.
But bear in mind I don't have an Akra system so the fuelling could be well off.
Have you considered an auto tune module instead?
I was just going to experiment with your map. If it feels better and I can see a difference then will have to hunt out a Dyno tuner. If not I will just revert back to standard map. According to Dynojet and Akrapovic there is no need to remap when using the Akra pipe so it will be interesting.
