CBR650R ABBA Superbike stand usage on 2024 CBR650R e-clutch
mrzubair
Aug 3, 2021
Hello All,
Was checking to see if anyone is using the ABBA superbike stand for the 2024 CBR650R e-clutch. I was doing my pre-delivery goodies shopping (exciting times) and have this on my shopping list. Just wanted to ensure that the protruding e-clutch does not get in the way (even slightly).
If all is well, I was planning to get the Superbike Package 2 which includes the wheel lift attachment.
If anyone is using it (even the base superbike stand), then a pic would certainly do the 1000 words magic.
Redrocket
Mar 17, 2023
I can't try it on an E-clutch but I've just had a look at how my Superbike Stand locates on my 2023 CBR650R on the r/h side and how it moves as the stand is used. I'd say that it'll be fine because the bulge of the E-clutch is ahead of where the stand locates and anyway there looks to be enough clearance. The way the front extension stand fits won't be affected by the E-clutch either. The Superbike stand is a terrific bit of kit IMHO as it is so easy to use single-handedly and with the optional extension the front wheel can be lifted separately from or together with the rear wheel. I also have the additional fitting to be able to remove the swinging arm and am currently trying to sort out the fittings for my CL500.
mrzubair
Aug 3, 2021
Sold ;)
Thanks chief for the empathetic response.
Redrocket
Mar 17, 2023
These stands have a lot of adjustability and there are fitting kits for a lot of bikes. Short of their Skylift they're by far the best in my view.
