I can’t find definitive info if we do have it in the USA or not but so far it looks like notI'm not 100% sure usa model bikes have hiss fitted... Which would be easy to get another key cut.
Might be different on the 650r models though.
If you have HISS it says it around the ignition cylinder, but everything I have ever seen, read and experienced says the US does not get HISS ignitions.I can’t find definitive info if we do have it in the USA or not but so far it looks like not
Great I guessSee these threads: https://650f.bike/tags/hiss/
as per above, if your bike is IMMO equipped it will say HISS on the ignition cylinder. Most USA bikes (if not all) are not HISS equipped. Bike theft is low here, so AHM specs them w/o to reduce cost.
